Elliott
- Sep 13, 2019
Does FreeNAS support any kind of scripting? For development, I am frequently creating and destroying pools. With many nested vdevs this can be time-consuming to repeat the same process using the GUI. If I create a pool using the command-line then FreeNAS does not recognize it. So is there any way to automate the process of creating pools in a way that FreeNAS will understand?
