I currently have 10 3TB drives. The pool consists of the 10 drives in 5 vdevs which are mirrored (Is that the correct terminology?) Apologies if not.
I have ran out of room in my case. The drives are 4 years old so keeping them is only likely to cost more in the long term. I was looking to get a bigger case to accommodate the older drives and some new ones but not sure if it makes sense to spend a lot on a bigger case when I can really do with just getting rid of the older/smaller drives to free up space, if that makes sense.
If I purchase 4 x 8tb drives, can I setup a new pool using those drives, copy all data to them then remove the other 10 drives thus freeing up space in the case again?
Or, is it better just to use more disks to the point of having more resiliency, in theory but at some point, I do not want to continue using the 3TB disks forever.
