silvioslim
- Dec 2, 2021
Hi there...i'm a brand new user on TrueNas (latest version) and use it on a i5-7500t 4 core cpu with 8gb ram ddr4 and 120Gb SSD only for the sistem and my intention is to use it with Plex Media Server.
First question is: i use 2 USB Hard Drive. First is only for the Plex Plugin (64Gb ssd) meanwhile the second is a classic HD (tried only with 2 media in 2160p 10bit to try out). This configuration could be a problem? Or it could be better if i use the same hard drive for plex plugin and media?
Anyway I installed Plex Media Server, create the pool with Windows Samba...so I can see the folder with the media and configure out Plex.
The problem is that after 1h watching 2160p 10bit movies it stopped and the CPU was at 100%. The problem could not be the movies resolution and format because use it on another nas (asustor)and works fine and never reach 100% cpu usage (not even the ram usage).
How can i fix this problem? Any suggestion? Thanks anyway
