Can someone explain the correct way to create and enable swap space on my FreeNAS 11.3 box?
I've added a new empty disk, currently assigned ada4.
What do I do now? I haven't done this before so I really need it step by step.
Especially I'm concerned because I routinely add and remove disks. So if I manually add a static line to fstab, referrencing ada4, won't it end up pointing to the wrong device, maybe part of my pool, some time when I reboot? Or will my manual entry conflict/be overwritten by the FreeNAS code, which presumably expects to manage fstab itself? So I'm looking for a way to say, in the GUI, "Use this device/partition as swap". But I can't figure it out, and don't have a clue what to do now.
Help please! Thanks!
