JohnAtl
- Sep 9, 2021
The exact error is "Selected certificate does not have a private key"
I discovered this when I tried to correct the time zone setting.
Even if I leave it at the same setting, I still get the error when trying to save the config from System | General.
There is also what is probably a related error about redirecting http to https.
If I look in System | Certificates, the freenas_default cert is there, and the Signing Request and Private Key are both empty.
I cloned my VM and did a reset, and the error was resolved.
I looked at the config I downloaded, and there is an entry in the sqlite db for the certificate, but I feel like making a change there and reuploading isn't the correct strategy.
Thanks for any suggestions!
error CRITICAL Web UI HTTPS certificate setup failed. 2021-10-09 14:03:10 (America/Los_Angeles)
