I am going to be adding four more drives to my FreeNAS box as a RAID 10 pool and am concerned about cooling. Currently the box has 6 drives in an IStarUSA D-416 case; they are all spaced evenly apart with space for a hard drive between each drive. This arrangement keeps the drives at acceptable temperatures with the front face open (30 - 33C idle and 35 - 37C under load) but it is starting to get warmer here and I'm concerned that adding 4 drives in the free spaces will really bring the temps up. This will mean that there will be 5 drives packed directly together on each side.
The cooling in these cases isn't great but I was able to zip tie 120mm cheapo Coolermaster fans directly in front of both stacks of hard drives which is how I was able to get the reasonable temps I have now. I have toyed with the idea of making a custom fan back plane and adding some real fans but I was wondering if anyone has some recommendations on fans that I might be able to drop in as direct replacements for the current 120mm ones. I will drop the new drives in and see what happens to the temps under different scenarios and report back but I don't imagine i will be able to get away with my current setup. Any recommendations would be most welcome.
Link to the case: http://www.istarusa.com/istarusa/pr...sub=D VALUE&model=D-416&factor=4#.UcMKnZzosa4
