Hi All,
I wanted to get to the bottom of some strange behaviour in my TrueNAS Core 13.0-U2 system. I have a couple of large Samba shares configured here and all seems to be working fine. But my /var/log/samba4/log.smbd file is constantly flooded with the following errors:
I think this may have something to do with some samba misconfiguration on my part. I did not find much on the vfs_ixnas module online or elsewhere in the forums. So I'm seeking the help of the TrueNAS and Samba experts here to help me get to the bottom of this. Any help would be greatly appreciated.
My share configuration is as follows:
All the files in the share are set up to be owned by the root user and the wheel group (hence the inherit owner and inherit permissions in the configuration above). There are 2 users that access these shares for whom permissions to do so are provided via appopriate ACLs - 1 user has complete read/write access and the other has readonly access.
[2022/09/28 19:04:04.495591, 1] ../../source3/modules/vfs_ixnas.c:134(ixnas_set_native_dosmode) ixnas_set_native_dosmode: Setting dosmode failed for /path/to/some/shared/file.pdf: Operation not permitted
# Global parameters
[global]
bind interfaces only = Yes
disable spoolss = Yes
dns proxy = No
enable web service discovery = Yes
kernel change notify = No
load printers = No
logging = file
max log size = 5120
registry shares = Yes
restrict anonymous = 2
server multi channel support = No
server role = standalone server
server string = TrueNAS Server
unix extensions = No
fruit:nfs_aces = No
idmap config * : backend = tdb
directory name cache size = 0
dos filemode = Yes
[MyShare]
case sensitive = Yes
comment = My Documents
ea support = No
inherit owner = windows and unix
inherit permissions = Yes
kernel share modes = No
path = /mnt/tank/myshare
posix locking = No
read only = No
smbd max xattr size = 2097152
vfs objects = fruit streams_xattr shadow_copy_zfs ixnas zfs_core aio_fbsd
fruit:resource = stream
fruit:metadata = stream
nfs4:chown = true
