Constant 100k Activity on an new, empty FreeNAS Box
I'm seeing a constant activity of 100k bytes on both the disks that I have in mirrored configuration. The HDD activity lights indicates that there is always some activity. I've even tried turning off syslog on the disks.
Is this normal ?
D
dlavigne
Guest
FN version? Any services running? Anything in /var/log/messages?
Version = 9.2.1.9
Services = CIFS
/var/log/messages:
Multiple times :
May 6 18:35:21 freenas smbd[40206]: [2015/05/06 18:35:21.298920, 0] ../source3
/lib/util_sock.c:1199(get_remote_hostname)
May 6 18:35:21 freenas smbd[40206]: matchname failed on 192.168.1.137
May 6 18:42:08 freenas smbd[40267]: STATUS=daemon 'smbd' finished starting up
and ready to serve connectionsmatchname: host name/name mismatch: 192.168.1.137
!= (NULL)
May 6 18:42:08 freenas smbd[40267]: [2015/05/06 18:42:08.741528, 0] ../source3
May 6 18:42:08 freenas smbd[40267]: matchname failed on 192.168.1.137
May 6 18:42:08 freenas smbd[40268]: STATUS=daemon 'smbd' finished starting up
!= (NULL)
May 6 18:42:08 freenas smbd[40268]: [2015/05/06 18:42:08.746666, 0] ../source3
May 6 18:42:08 freenas smbd[40268]: matchname failed on 192.168.1.137
May 6 18:47:23 freenas smbd[40333]: STATUS=daemon 'smbd' finished starting up
!= (NULL)
May 6 18:47:23 freenas smbd[40333]: [2015/05/06 18:47:23.510925, 0] ../source3
May 6 18:47:23 freenas smbd[40333]: matchname failed on 192.168.1.137
May 6 18:47:23 freenas smbd[40334]: STATUS=daemon 'smbd' finished starting up
SweetAndLow
Sweet'NASty
Or by setting up DNS correctly.
Robert Trevellyan
Pony Wrangler
You mean solve it properly, instead of just working around it? Sorry, not following...
After turning off writing any logs by CIFS, and turning off hostname lookups, and most importantly turning off plex plugin, I'm now seeing something like the image attached.
If it is infact plex that is causing these issues, I can take it up to them. But, are the 5 minute interval spikes normal operation ?
mjws00
The 5 minute spikes are normal. They are the reason there are so many threads about pools not going to sleep etc.
