Console log message read error?
larzeb
I am running FreeNAS-8.0.1-BETA4-amd64 with a raidz zfs volume containing 4 disks.
On the console, I see the following message:
g_vfs_done():ufs/FreeNASs1a[READ(offset=-286710323200, length=4096)]error = 5
It is listed 5 times in the last few days. Being a total beginner, I do not know how to interpret the message and how to correct it.
Thanks for any help with this.
ProtoSD
Hi Larzeb,
This looks like a read error with your flash disk that has FreeNAS. You could try reflashing it after you backup your settings. The only other thing I can think of to try would be if you had a regular FreeBSD system, you could run 'fsck' on that partition. I'm not really sure how fsck works on flash parititions. It's probably easier to reflash and see if that helps.
