Configuring ZFS Scrubs question
DJVege
Hi guys,
I've read the doco but I'm still a little unsure as to how to setup what I want. If I want a scrub to begin once a month, on a Sunday at 2am, how do i set that up? Do I set the threshold to 30 days?
I want the scrub to run once a month, always on a Sunday at 2am.
Thanks.
J
James
Guest
The threshold needs to be divisible by 7 to always run on the same day of the week. So you could set it to 28 or to 35.
DJVege
Thanks.
Set it up and will hopefully run this Sunday, and once a month on a Sunday from now on.
...DJVege...
DJVege
Hi all,
Although I thought I set the scrub up to ONLY run on Sundays at 2am, it started this morning at 2am because the threshold was met (35 days since last scrub). Can someone please shed some light on what options I need to set on the ZFS Scrub page to set this to run once a month on Sundays at 2am?
Thanks.
I'd wait and see when the next one is triggered. It might be a situation where the first scrub will be out of sync, but the remaining will.
DJVege
Ah ok. Fair enough. This was definitely my first scrub since install, so maybe that is it..??
Cheers.
DJVege
Hey guys,
I'm just putting my config here anyway for someone to verify:
volume1 (ZFS)
Threshold: 35
Minute: 00
Hour: 02
Day of month: 07,08,09,10,11,12,13
Month: Every month
Day of Week: Sunday
Is this right? Will this only ever run once every 35 days, but only on a Sunday..??
freshfeesh
I was just wondering the exact same thing (although I'm going for twice a month). It's not at all clear to me, after reading the documentation, how threshold and the rest of the triggers interact - must both be true (threshold met AND day selection met), or either (an OR relationship). What do the Hour and Minute settings do when the above is resolved? If more than one hour is selected, does it run at each of those hour triggers, but only on the selected day, e.g. say DJVerge gets one Sunday a month working, and more than one hour set. Will it run multiple times, at those selected hours, on that Sunday only? Then what about the minutes - will it try to run at each of the selected minutes, during each of the selected hours only, only on the triggered day? It would make sense to me if you were able to set Threshold days only, or every/selected minute only, or every/selected hour only. As it is, making use of all of those parameters would seem to result in clustered, erratic scrubs, which I don't understand the point of. Finally, we get to days of the month vs. day of the week. Setting either or would make sense, but what does both do? An AND relationship or an OR relationship? I'm confuse.
paleoN
That's because it's cron. Read the man page on it, the examples help.
Month: Every month
Day of Week: Sunday
Nope. It won't run on any Sunday that is before the 7[sup]th[/sup]. You can have all the days enabled. E.G.:
00      02      *       *       7       root    PATH="/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:/root/bin" /usr/local/sbin/scrub -t 14 tank
is what it put into crontab for a scrub set for Sunday at 02:00.
DJVege
Ooh... Thanks paleoN. Makes sense to me now.
With what I have set above, will the scrub only run:
* If the threshold has passed 35 days
* If the day of the month is between 7th and 14th of the month
* If it's a Sunday
* If it is 2am.
The cron will wait till all the above is true, then run the scrub?
Is my understanding correct?
paleoN
Almost. ;)
The scrub script will run every Sunday between the 7[SUP]th[/SUP]-14[SUP]th[/SUP]. If the 7[SUP]th[/SUP] and the 14[SUP]th[/SUP] were both Sundays cron would run on it on both of the days.
The threshold value is passed to the scrub script. If it has scrubbed recently then the scrub script won't actual start another scrub.
DJVege
haha. Ah ok. My logic was wrong.
Sweet. So playing with the dates, I can limit the scrub to only run during certain times of the month, or I can just open it up to run once every 4-5 weeks, on whichever Sunday it falls on.
Thanks again, mate. Much appreciated.
freshfeesh
PaleoN, thanks for the explanation. It would have taken me a long time to figure that out by playing around with it. So here's my conclusion:
Scrub runs IF( (Threshold Days met) AND (Minute, Hour, Month, AND Year met) AND (Day of Month OR Day of Week met) )
Given that Threshold can't be less than 1 day, the scenario that I was wondering about earlier with scrubs at multiple minutes of multiple hours of specific days wouldn't occur.
paleoN
Glad it helped. Especially since it was inaccurate! I was thinking DoM & DoW was another AND. It's been a while since I played with cron.
nims076
Can someone please confirm if the below set up is ok for a scrub to run once a month on the 1st of each month?
Also, how often do you recommend a scrub is run?
volume1 (ZFS)
Threshold: 28
Minute: 00
Hour: 09
Day of month: 01
Month: All ticked
Day of Week: All ticked
It was removed in the 8.2 manual, but 8.0.3 recommended weekly scrubs for consumer-quality drives and datacenter-quality monthly scrubs.
paleoN
Looks fine. Double check crontab if you are concerned.
