SOLVED command runs in shell, but not in script
4est
I am trying to implement a script that backs up a folder 2times/week, and then deletes backups older than ~60days.
I've used this script on gentoo and ran flawlessly
However I can not seem to implement it to my FreeNAS
The script was using zip, but as zip is not included into FreeNAS I switched to tar.
My basic problem is that I can not seem to run tar in a script.
I have simplified the command:
tar -vcf /mnt/DATA.tar fld
running in shell works ok
running in script /bin/sh -x scipt.sh:
+ tar -vcf DATA.tar fld
: Cannot stat: No such file or directory
tar: Error exit delayed from previous errors.
I tried using absolute paths, still not working.
Thanks
4est
I solved it: the problem was caused by ^M character (the script was written on windows)
melloa
Yeap ... windows. I was about to say that I had no idea, even tested:
[root@backupnas] /mnt/raid# sh tardir.sh
tar: Removing leading '/' from member names
a mnt/raid/scripts
a mnt/raid/scripts/syncdatasets.sh
a mnt/raid/scripts/syncallcifs.sh
a mnt/raid/scripts/cover.txt
a mnt/raid/scripts/copyconfig.sh
a mnt/raid/scripts/ersync.sh
[root@backupnas] /mnt/raid# less tardir.sh
#!/bin/bash
tar -vcf compressedfiles.tar /mnt/raid/scripts
