Vesto Slipher
- Jul 3, 2019
Hello everyone, first time poster so please go easy on me.
I have been thinking of using FreeNAS to build myself a backup and long term storage server for a few years now. Recently my boot SSD died and now I am going to have to get the data recovered. It did also contained important personal files.
This has really made me realise that I can't postpone this any longer and come hell or high water, I will build one.
For reference, I live The Netherlands.
The total amount of data I have to back up is about 6 TB. Add to that between 5-10 TB of family photo's, video and old files which are spread on about half a dozen external hard disks.
Motherboard: Supermicro MBD-X10SDV-2C-7TP4F.
https://www.beat-it.nl/super-micro-...&utm_medium=vergelijker&utm_campaign=datafeed
HDD: WD RED 6TB x8.
https://www.amazon.de/WD-Red-6TB-interne-Festplatte/dp/B00LO3KR96/ref=sr_1_1?__mk_nl_NL=ÅMÅŽÕÑ&keywords=wb+red+6+tb&qid=1562332965&s=gateway&sr=8-1&th=1
Case: 4U server case 20x3.5" hot swapbays.
https://www.servercase.co.uk/shop/s...-+-1-x-slim-optical-drive-650mm-deep-sc-4320/
This is as far as I have gotten since I don't know which power supply or RAM I would need to feed it all. I am looking to get 32GB of ECC ram. Any suggestions would be welcome.
The idea is to have 8x 6TB drives in a raid z2 configuration and when the need arises in the future, add another 8 even larger drives in a second vdev also z2. I can then transfer all the info on the first vdev to the second vdev and retire the old drives. I understand that at that point I will need more RAM. The 20 drive case also gives me the space for another 4 drives in a third vdev.
Future expansion could be adding a m.2 drive as a L2ARC
If you see anything wrong or have any suggestions then please comment. I welcome it.
I do have a number of questions.
1. Can I convert 4 sata ports into a mini-SAS to connect to the panel inside the case where they will then be converted back to 4 sata ports in the hotswap bays?
2. I would like to us this as a local backup, long term storage (photos) and plex server (music). is this possible?
3. Are the red pro drives worth it? Each is 50 euros more expensive.
Any help is appreciated.
HDD: WD RED 6TB x8.
