Collabora + Nextcloud - 404 error?
papajohn56
Hi all -
I'm on TrueNAS SCALE and trying to run Collabora as my NextCloud office instance, both via the standard app installs (not TrueCharts). Everything seems to be installed properly, but updates to Collabora apparently broke how it gets accessed - I keep seeng references to "cool" vs "lool" in posts, but have found no definitive fixes that made sense to me. Right now when I try to load the instance, I get a 404 error from nginx. Nextcloud says the server for Collabora is active, but files fail to load in NextCloud office.
Is there some sort of setting in nginx config I'm missing and need to change?
Thank you
papajohn56
To add - my versions:
App Version: 23.05.8.4.1
Chart Version: 2.0.4
App Version: 28.0.2
Chart Version: 1.6.57
