ryanwclark
- Apr 6, 2019
I found that as of 11.3 the functionality in CloudSync was changed or at least the documentation would lead me to believe it was changed from 11.2 to 11.3. I am currently using 11.3 but want the behavior described in 11.2, as I would prefer not to copy all files at my various cloud storage providers as described in the 11.3 documentation but rather copy only the new files and skip already existing identical files. I also found the documentation on rclone.org for rclone copy, which I thought (could be way off here) was being used for this feature in FreeNas/TrueNas.
Does anyone have any additional insight?
Rclone.org
Sync the source to the destination, changing the destination only. Doesn't transfer unchanged files, testing by size and modification time or MD5SUM. Destination is updated to match source, including deleting files if necessary.
11.2
Sync (default) makes files on destination system identical to those on the source. Files removed from the source are also removed from the destination, similar to rsync --delete.
Copy copies files from the source to the destination and skips files that are identical, similar to rsync.
Move copies files from the source to the destination and deletes the source files after the copy, similar to mv.
11.3
SYNC: Files on the destination are changed to match those on the source. If a file does not exist on the source, it is also deleted from the destination. There are exceptions to this behavior.
COPY: Files from the source are copied to the destination. If files with the same names are present on the destination, they are overwritten.
MOVE: After files are copied from the source to the destination, they are deleted from the source. Files with the same names on the destination are overwritten.
Rclone.org
11.2
11.3
