nathank1989
- Aug 29, 2016
I have set up a Cloud Sync task to my Sharepoint Document site and so far it seemed everything was uploaded. After letting it run, I noticed about 25gb worth of data missing and saw a log of errors. Below is a sample of the errors that cause rclone to fail
How can I fix this?
Downloading the full logfile shows hundreds of similar errors for various file types. At first I thought some were quirky and needed to be renamed or removed (like *.ini files)
Cursory google searching brought me to the Github for rclone where people said that --ignore-checksum (?) switch needed to be added to forgo this error and force the sync anyway.
How can I fix this?
2019/02/04 12:01:02 INFO : Transferred: 0 / 0 Bytes, -, 0 Bytes/s, ETA - Errors: 0 Checks: 13 / 13, 100% Transferred: 0 / 0, - [20787 more lines] 2019/02/04 12:26:19 INFO : Work Documents/SITE1/DMO/packages/ULs/Print Drivers/RICOH MP 301SPF/PCL6 V4 UP/disk1/README.html: Removing failed copy 2019/02/04 12:26:19 ERROR : One drive root '': not deleting files as there were IO errors 2019/02/04 12:26:19 ERROR : One drive root '': not deleting directories as there were IO errors 2019/02/04 12:26:19 ERROR : Attempt 3/3 failed with 435 errors and: corrupted on transfer: sizes differ 21200 vs 21416 2019/02/04 12:26:19 Failed to sync: corrupted on transfer: sizes differ 21200 vs 21416
