danzg
- Jun 18, 2011
After a colleague bumped into the server, I'm getting this:
This means I should replace ada2p2, right?
I tried this:
Should I do
Or can I do this from the GUI?
Or should I just 'zpool clear' ?
Thanks!
zpool status pool: raid-5x3 state: ONLINE status: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected. action: Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'. see: http://www.sun.com/msg/ZFS-8000-9P scrub: scrub completed after 15h35m with 0 errors on Mon Oct 22 15:46:55 2012 config: NAME STATE READ WRITE CKSUM raid-5x3 ONLINE 0 0 0 raidz1 ONLINE 0 0 0 ada1p2 ONLINE 0 0 0 ada2p2 ONLINE 0 0 4 ada4p2 ONLINE 0 0 0 ada5p2 ONLINE 0 0 0 ada3p2 ONLINE 0 0 0 spares ada0 AVAIL errors: No known data errors
I tried this:
zpool replace raid-5x3 ada2 ada0 cannot replace ada2 with ada0: no such device in pool
Should I do
zpool replace raid-5x3 ada2p2 ada0
Thanks!
