nudzimisie
- Sep 2, 2011
The Issue:
After creating a samba share with guest access, when attempting to access the share from my XBMC or multiple macs, it would appear unresponsive. AFP and NFS appeared to work just fine, however XBMC was not able to see the samba share whatsoever and the macs would take over 1 minute to access the share (no authentification prompt or guest option).
My Temp Solution:
After doing a reset to default settings, the issue immediately went away.
When I began to change settings for the CIFS shares, it came back. After a few hours of trial and error, I came to the following realization:
1) The netbios name MUST be in all lowercase
2) The workgroup name cannot be changed
3) The netbios name MUST match the hostname
If these three conditions are not met, then my samba begins to act very slowly, with slow transfers, or no recognition whatsoever. This is true for both of my FreeNAS configs (two different machines).
System Config:
OS Version: FreeBSD 8.2-RELEASE-p1
Platform: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
FreeNAS Build: FreeNAS-8.0-RELEASE-amd64
Hope this helps someone in the future!
My Temp Solution:
System Config:
