solarisguy
- Apr 4, 2014
“in real life™, access to the same storage area using multiple protocols is a highly desirable feature. Even if locking remains incompatible”
I think file corruption can be avoided entirely if you add the auxiliary parameter "oplocks = no" to the share definition of a share being modified locally or through NFS. This will degrade performance because clients won't cache files.I seriously hope this 'feature' doesn't make it in the final product or if it does, we can turn it off.
Do not punish those of us that know what we're doing because of the actions of a few. I simply cannot use freenas if this were to come about.
But I don't need to do these things. LOL. I have been operating my shares this way for over 12 years on my home network. I still maintain that I know what system is modifying what files at what times.I think file corruption can be avoided entirely if you add the auxiliary parameter "oplocks = no" to the share definition of a share being modified locally or through NFS. This will degrade performance because clients won't cache files.
If you decide to use 'unix permissions' on a CIFS share, be sure to disable the zfsacl vfs object.
Of course. I was thinking in terms of a larger environment. :)But I don't need to do these things. LOL. I have been operating my shares this way for over 12 years on my home network. I still maintain that I know what system is modifying what files at what times.
Post link to said ixsystems video with unix permissions on a CIFS share. I'd love an opportunity to troll cyberjock.Curious, if this is such a big deal (mixing Unix permissions on a CIFS share), then why is the option even there? I will fully admit to being a novice with this, but I have been struggling with the permissions just on a single Windows box and FreeNAS. Seems like the only way I've been able to get it to work so far is with this very no-no way of doing it. I've watched a number of videos and such, a few made by IXsystems too, and during the video they leave the Unix permissions on a CIFS share.
I don't see this in the list of available or selected VFS objects in 9.3.If you decide to use 'unix permissions' on a CIFS share, be sure to disable the zfsacl vfs object.
To be fair, the Unix/Windows options are properties of datasets, not shares.if this is such a big deal (mixing Unix permissions on a CIFS share), then why is the option even there?
that's before the devs realized how Samba works internally ... anything before the summer of 2015
Leave it. It's fineSo I have a question specific to these last few comments. I have my media dataset currently set up with Unix permissions and have a CIFS share to access it via Windows PCs. This is primarily due to the video I mentions, where they don't really go into any detail either way on how to setup the dataset. I have Plex in place and all seems to be working fine as related to Music, Photos and a few home videos that I've added. My questions are this, (1) what are the implications of leaving it alone and (2) what are the implications of changing it to Windows permissions given that I have now added all of my Music and Photos? If I do change this over to using Windows permissions, I assume I would want to enable the Set the Permissions Recursively checkbox...correct?
That's because it's explicitly excluded from the listing of available vfs modules in freenas/gui/choices.py:I don't see this in the list of available or selected VFS objects in 9.3.
class CIFS_VFS_OBJECTS(object):
def __init__(self):
self.__vfs_module_path = '/usr/local/lib/shared-modules/vfs'
self.__vfs_modules = []
self.__vfs_exclude = [
'zfsacl',
vfs_objects = []
if task:
vfs_objects.append('shadow_copy2')
if is_within_zfs(share.cifs_path):
vfs_objects.append('zfs_space')
vfs_objects.append('zfsacl')
vfs_objects.extend(share.cifs_vfsobjects) vfs objects = zfs_space streams_xattr
Fortunately I'm the only user, and the primary use for CIFS is to backup one Windows machine via an authenticated connection. I occasionally set up a read-only share in the context of a data recovery operation, and haven't had any problems with that either. I believe all my CIFS-related settings are pretty much default. Maximum protocol is set to SMB2.Note that these issues primarily affect people in multi-user environments
#@%&!Yeah.. that's before the devs realized how Samba works internally to do permissions along with lots of other "seat belts".
Basically anything before the summer of 2014 is probably really bad advice.
Edit: Sorry, I meant summer of 2014.. not 2015.
If it's a home setup, don't fix it if it ain't broke.#@%&!
I see PirateGhost saying it's fine for the moment, so I'll probably leave my setup alone until recommendations become somewhat uniform, but this is not the news I wanted to hear today. Sigh....
What's the current (at least short term) advice? Let sleeping dogs lie if an existing share is working OK, but don't set it up this way on a new share?
