Change port number
csjjpm
I've tried to search for the ports.conf file in the jail but can't find it. Does anyone know where I find the files I need to change the port number in?
thanks
Paul
ports.conf seems to be something that refers to apache2, not FreeNAS in particular.
Did you install apache2 in your jail? (what method did you use?)
If apache isn't related to what you're trying to do, please expand a bit on what you want to change the ports for.
