centos 6.4 x64 jail seems to run in 32 bits
iXô
Hello, I tried to install Zimbra in a centos jail.
The url for the jail makes me think that it would be a 64 bits jail.
But during installation of Zimbra it fails as the jailed environment seems to be 32 bits.
Is it normal ? or is it a bug ? Is it possible to have a 64 bits centos jail ?
Thanks.
Best regards.
iXô
Ok, my bad, thanks for your answer.
Do you have a full mail solution that I can use instead ?
D
dlavigne
Guest
Depends upon what you're looking for. You can either do a search for a specific app at freshports.org or browse through the mail category at http://www.freshports.org/mail/. If one you want is in there, install it in a Plugins Jail using the instructions in the Jail chapter of the docs.
