Cant restore data from a shadow copy, no admin permissions?
Dariusz1989
Hey
I had a power crash today and my freenas/truenas restarted.
It is an old system updated over the past 2 years.
The odd thing is this time is that if I go to shadow copies (on windows) and try to restore older version, I just get error :
TrueNAS-12.0-U6
I'm a tad lost with this. I take I need to somehow restore permissions? How can I bite it?
Seems like any folder anywhere is locked away from me O.O
Halp!
anodos
Sambassador
Hey
TrueNAS-12.0-U6
Halp!
Can you copy the file out of the dir (rather than using the "restore" feature)?
Dariusz1989
I cant do anything.
If I open shadow copies old ones, I have no control over any of them.
If I try to check security settings of current files I just get >
Its like entire directory & copies are now blocked away O.O
I can't edit permissions from under Windows. Can I do it somehow manually from under truenas?
I can access other files in other directories, still testing, but this 1 dir somehow broke. its odd!!!
I did this >
getfacl /mnt/path/to/dataset
These are some funky permissions O.O
