RagingRyno
 - Apr 21, 2013
Hi all, I am a n00b, that being said I'll get started.
I have butchered an old PC and installed FreeNAS 8.3.1 on a USB stick, I first installed a single old drive in UFS to test it out. Well it all worked great so I added a 1TB WD Green drive, there was my first mistake, by me trying to add a NTFS drive to it the HDD partition broke, but luckily I managed to recover all the data. Once I did that I removed the existing old drive and put in my brand new WD Red 3TB, formatted to UFS, and started copying my data accross. All was working fine till I added the green drive back in and then FreeNAS seemed to be confused as to what drives were actually in there.
I read on a forum that a fresh install on the USB might do the trick then I can Auto Import the drive back in. Sounded like a good plan, once I did that I looked in 'view disks' and both were there, sweet. So I put a new volume on the now recovered 1TB Green drive no worries. Then went to auto-import the 3TB red drive with my data on it and...nothing. When I tried the Auto-Import function it didn't find any volumes to import. When I tried the 'Import Volume' function it shows the 3TB drive there, I type in the volume name, select the drive, select UFS, hit go and it gives me this error 'The selected disks were not verified for this import rules.'
And now I'm stumped. I have tried searching for this issue but most questions out there seem to be referring to ZFS and not my issue.
Pleeeeeeeeeeeeeeeeeeeeeeeease help!
Thanks in advance
Thanks in advance
