Hi
I can't write with more than 10 mbyte/s to my hdd (dd zero to disk 16m)
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD20EARS-00MVWB0 51.0AB51> ATA-8 SATA 2.x device
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
If I boot in a normal 8.2 fixit shell (from the install media) it doesnt see it as ada0 but da4 - and there I can dd with 150 mbyte/s
I can't seem to grasp why I cant get past the 10 mbyte/s via freenas
The bios is set to ACHI
(windows also gives 100mbyte+/s)
Edit: Tried to make a clean 8.2 install and enable ACHI in that.. and boom they went down to 10mbyte/s seems to be the "driver" or something... (not that good at freebsd yet)
