Can't get into sabnzbd 1.0
muaysub
After i updated sabnzbd plugin to 1.0 i can't get access it. I have tried to uninstall and install it again but still no luck, the service is started but i can't get in... I get "Can't reach this page"
I have also checked for conflicts for IP number but nothing there either so I dont understand why im not getting in.
Running FreeNAS-9.3-STABLE-201602031011
What can i do? Any ideas?
Joshua Parker Ruehlig
did you try restarting the jail?
does a fresh install work for you?
I noticed in another thread sabnzbd was listening only on 127.0.0.1
please show the output of sockstat.
maybe since youbare using dhcp sabnzbd doesn't know what IP to bind to by the time it is started
muaysub
Have tried restart and fresh install of the plugin but still the same problem...
root@sabnzbd_1:/ # sockstat
USER     COMMAND    PID   FD PROTO  LOCAL ADDRESS         FOREIGN ADDRESS
media    python2.7  34013 5  tcp4   127.0.0.1:8080        *:*
root     python2.7  19562 3  tcp4   192.168.1.201:12352   *:*
root     cron       17291 4  dgram  -> /var/run/logpriv
root     syslogd    17238 4  dgram  /var/run/log
root     syslogd    17238 5  dgram  /var/run/logpriv
root     syslogd    17238 6  udp6   *:514                 *:*
root     syslogd    17238 7  udp4   *:514                 *:*
?        ?          ?     ?  tcp4   192.168.1.201:12352   192.168.1.150:38632
?        ?          ?     ?  tcp4   192.168.1.201:12352   192.168.1.150:38648
root@sabnzbd_1:/ #
I'm not using dhcp for the jail, I have attached a screenshot for my settings.
I'll investigate tonight. I might need to modify things to have the plugin listen on all IPs by default.
Ok, I fixed this in the sabnzbd plugin but didn't bump the version (to keep in line with the official port).
The md5 of the correct PBI is "737327c73d33892d7a0d6aa" and it should be available normally from the freenas repo tomorrow.
If you'd rather patch an existing v1.0.0 install please run the following commands in sabnzbd's jail
service sabnzbd stop
sed -i '' -e 's/\(^command_args=.\)\(.*\)/\1-s 0.0.0.0 \2/' /usr/pbi/sabnzbd-amd64/etc/rc.d/sabnzbd
service sabnzbd start
