Can't disconnect old volume
henderbc
I'm unable to disconnect or export an old volume that is no longer being used. The volume is(was) on a single striped disc (ada2) which is installed, but the status of the volume is shown as UNKNOWN (see below)
When I try to Export/Disconnect the pool, I get:
If I try #zpool export volume4, I get cannot open 'volume4': no such pool
Any ideas? I don't need this volume and I don't care what happens to the content of the disk.
Samuel Tai
Try zpool destroy -f volume4.
henderbc
root@FREENAS2[/]# zpool destroy -f volume4
Samuel Tai
What about zpool export -f volume4?
henderbc
root@FREENAS2[/]# zpool export -f volume4
Samuel Tai
What does zpool status -v show?
henderbc
Sorry: I had to be away for a while, but I really do appreciate your help Samuel. This is driving me nuts!
root@FREENAS2[/]# zpool status -v
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:05 with 0 errors on Sat Jul 4 03:45:05 2020
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
errors: No known data errors
pool: volume3
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
scan: scrub canceled on Tue Jun 30 08:05:40 2020
volume3 ONLINE 0 0 0
gptid/3e8a56d9-8afd-11e8-9bdb-d0509945e6d6.eli ONLINE 0 0 0
root@FREENAS2[/]#
It seems that volume4 has an dangling entry in a database somewhere, and the drive that used to be volume4 (ada2) is present, but zpool doesn't know how to get rid of the volume4 entry.
Apollo
pool: freenas-boot
state: ONLINE
ada0p2 ONLINE 0 0 0
pool: volume3
state: ONLINE
root@FREENAS2[/]#
Is "volume3" your pool or is it "volume4" .
Is this a typo?
henderbc
Nope, not a typo.
-ada0 is my boot drive
-ada1 (volume3) holds data
-ada2 (volume4) is the drive (volume) no longer in use and the one I am trying to get rid of.
Samuel Tai
Try a quick wipe of ada2, which clears the partition table, and then a reboot.
Samuel Tai
Under Storage->Disks, expand the unused disk. There should be a Wipe button.
