Hi all,
I have struggled with this for hours and can't work out how to progress. I am trying to replace all the 6x disks in an existing volume with a new set of disks (larger). I figured the easiest way would be to detach the volume, remove all the disks, create new volume and copy the data back from a backup.
However when I go to detach the volume I get "Error: Failed to detach volume1 with "zpool export volume1" (exited with 1): cannot unmount '/mnt/volume1/onsite': Device busy". The same happens if I try to export the volume on the CLI (even with -f).
/mnt/volume1/onsite is a dataset in the volume. I have tried turning off CIFS completely, trying to export straight after a fresh reboot but still get exactly the same error. If I run an fuser on the volume nothing shows up. There are no jails in this volume, it's just file data. Running latest version of Freenas.
Any suggestions are much appreciated.
