Hi guys i just install freenas on my home server i will try to create pool with one hdd 450gb but when i go to press create the system return to me thi error:
[EFAULT] Failed to wipe disk ada0: [EFAULT] Command dd if=/dev/zero of=/dev/ada0p2 bs=1m count=32 failed (code 1): dd: /dev/ada0p2: Operation not permitted
File "/usr/local/lib/python3.7/site-packages/tastypie/resources.py", line 219, in wrapper
response = callback(request, *args, **kwargs)
File "./freenasUI/api/resources.py", line 1421, in dispatch_list
request, **kwargs
File "/usr/local/lib/python3.7/site-packages/tastypie/resources.py", line 450, in dispatch_list
return self.dispatch('list', request, **kwargs)
File "./freenasUI/api/utils.py", line 252, in dispatch
request_type, request, *args, **kwargs
File "/usr/local/lib/python3.7/site-packages/tastypie/resources.py", line 482, in dispatch
response = method(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/tastypie/resources.py", line 1384, in post_list
updated_bundle = self.obj_create(bundle, **self.remove_api_resource_names(kwargs))
File "/usr/local/lib/python3.7/site-packages/tastypie/resources.py", line 2175, in obj_create
return self.save(bundle)
File "./freenasUI/api/utils.py", line 493, in save
form.save()
File "./freenasUI/storage/forms.py", line 282, in save
return False
File "./freenasUI/storage/forms.py", line 279, in save
}, job=True)
File "/usr/local/lib/python3.7/site-packages/middlewared/client/client.py", line 399, in call
return jobobj.result()
File "/usr/local/lib/python3.7/site-packages/middlewared/client/client.py", line 172, in result
raise ClientException(job['error'], trace={'formatted': job['exception']})
middlewared.client.client.ClientException: [EFAULT] Failed to wipe disk ada0: [EFAULT] Command dd if=/dev/zero of=/dev/ada0p2 bs=1m count=32 failed (code 1):
dd: /dev/ada0p2: Operation not permitted[EFAULT] Failed to wipe disk ada0: [EFAULT] Command dd if=/dev/zero of=/dev/ada0p2 bs=1m count=32 failed (code 1): dd: /dev/ada0p2: Operation not permitted
