Can't copy snapshot names from GUI
FreeNASBob
FreeNAS-9.3-STABLE-201512121950
I'm doing some command line stuff with snapshots and discovered that you can't copy snapshot names from the GUI. It appears that left and right mouse clicks are intercepted by some script on that page. I thought it was Firefox only, but it's not possible in Internet Explorer either.
Typing out those long periodic snapshot names would be a lot easier if we could copy them using standard mouse movements.
FreeNASBob
Did you find a workaround for this?
I haven't found one. I can't say I've tried real hard, but I did try a couple of browsers. The best I could do was view source and then search for the snapshot I wanted, but that's more work than just typing out the names on the command prompt.
