I am currently trying to connect FreeNAS 9.1.1 to my LDAP server (ClearOS 6.4 using OpenLDAP). The LDAP server uses SSL and listens on port 636. I can successfully connect to LDAP from my Windows machine using Apache Directory Studio and on the FreeNAS machine, the command
ldapsearch -x -v -H "ldaps://clearos.schnigges.lan" "uid=testclear"
results in the following output:
(not sure why the entry is not found, but at least the connection works).
When trying to start the directory service in the FreeNAS UI, I get the following error in /var/log/messages:
For some reason (don't know if it is just the output that is wrong or the actual command), smbd tries to connect using ldap:// instead of ldaps:// (is this a bug?).
My settings look like this:
Another info: I already changed the localsid on the FreeNAS machine as suggested in https://bugs.freenas.org/issues/1158
Any ideas what is going wrong?
ldap_initialize( ldaps://clearos.schnigges.lan:636/??base ) filter: uid=testclear requesting: All userApplication attributes # extended LDIF # # LDAPv3 # base <dc=schnigges,dc=lan> (default) with scope subtree # filter: uid=testclear # requesting: ALL # # search result search: 2 result: 32 No such object # numResponses: 1
Nov 19 21:03:52 Schnigges-NAS LDAP: /usr/sbin/service ix-ldap quietstart Nov 19 21:03:54 Schnigges-NAS LDAP: /usr/sbin/service ix-nsswitch quietstart Nov 19 21:03:54 Schnigges-NAS LDAP: /usr/sbin/service ix-pam quietstart Nov 19 21:03:55 Schnigges-NAS LDAP: /usr/sbin/service ix-samba quietstart Nov 19 21:05:48 Schnigges-NAS LDAP: /usr/local/bin/python /usr/local/www/freenasUI/middleware/notifier.py start cifs Nov 19 21:07:45 Schnigges-NAS notifier: dbus already running? (pid=47909). Nov 19 21:07:45 Schnigges-NAS notifier: Starting avahi-daemon. Nov 19 21:07:45 Schnigges-NAS notifier: Daemon already running on PID 47938 Nov 19 21:07:46 Schnigges-NAS notifier: Removing stale Samba tdb files: ....... done Nov 19 21:07:46 Schnigges-NAS notifier: Starting nmbd. Nov 19 21:07:46 Schnigges-NAS notifier: Starting smbd. Nov 19 21:07:46 Schnigges-NAS smbd[49717]: [2013/11/19 21:07:46.159760, 0] lib/smbldap.c:1225(smbldap_connect_system) Nov 19 21:07:46 Schnigges-NAS smbd[49717]: failed to bind to server ldap://clearos.schnigges.lan:636 with dn="cn=manager,ou=Internal,dc=schnigges,dc=lan" Error: Can't contact LDAP server Nov 19 21:07:46 Schnigges-NAS smbd[49717]: (unknown) Nov 19 21:07:46 Schnigges-NAS LDAP: /usr/sbin/service ix-ldap status
