Ok, I have read sooooo much. I am willing to read more if you point me somewhere. I even found a few threads with this same title (very similar.) But I still can't resolve my situation.
FreeNAS-9.2.1.6-RELEASE-x64 (ddd1e39)
Intel(R) Xeon(R) CPU E3-1226 v3 @ 3.30GHz
32402MB (ECC)
I have 6x2TB:
I *think* i bumped the cable when I put the cover back on the case. The drive *disappeared*. I shutdown and changed the cable. Now the drive is *there*. But I am unable to Online it or whatever. I scrubbed it and I did Online it, but none of that changed the status of UNAVAIL.
Tried to online it:
And the drive info:
So, should I just hit the "replace" button and see if it brings it back?
32402MB (ECC)
I have 6x2TB:
[root@freenas] ~# zpool status
pool: Deerhaven1
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: scrub repaired 0 in 0h7m with 0 errors on Sat Aug 9 20:14:20 2014
NAME STATE READ WRITE CKSUM
Deerhaven1 DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/38009294-1dcb-11e4-82ae-d05099013a39.eli ONLINE 0 0 0
6630984596155414364 UNAVAIL 0 0 0 was /dev/gptid/38b76d59-1dcb-11e4-82ae-d05099013a39.eli
gptid/3965262b-1dcb-11e4-82ae-d05099013a39.eli ONLINE 0 0 0
gptid/3a143aab-1dcb-11e4-82ae-d05099013a39.eli ONLINE 0 0 0
gptid/3ac8051b-1dcb-11e4-82ae-d05099013a39.eli ONLINE 0 0 0
gptid/3b79f677-1dcb-11e4-82ae-d05099013a39.eli ONLINE 0 0 0
errors: No known data errorsI *think* i bumped the cable when I put the cover back on the case. The drive *disappeared*. I shutdown and changed the cable. Now the drive is *there*. But I am unable to Online it or whatever. I scrubbed it and I did Online it, but none of that changed the status of UNAVAIL.
[root@freenas] ~# camcontrol devlist <WDC WD20EFRX-68EUZN0 80.00A80> at scbus5 target 0 lun 0 (ada0,pass0) <WDC WD20EFRX-68EUZN0 80.00A80> at scbus6 target 0 lun 0 (ada1,pass1) <WDC WD20EFRX-68EUZN0 80.00A80> at scbus7 target 0 lun 0 (ada2,pass2) <WDC WD20EFRX-68EUZN0 80.00A80> at scbus8 target 0 lun 0 (ada3,pass3) <WDC WD20EFRX-68EUZN0 80.00A80> at scbus9 target 0 lun 0 (ada4,pass4) <WDC WD20EFRX-68EUZN0 80.00A80> at scbus10 target 0 lun 0 (ada5,pass5) <PNY USB 2.0 FD 0.00> at scbus12 target 0 lun 0 (da0,pass6)
[root@freenas] ~# gpart show
=> 34 3907029101 ada0 GPT (1.8T)
34 94 - free - (47k)
128 4194304 1 freebsd-swap (2.0G)
4194432 3902834696 2 freebsd-zfs (1.8T)
3907029128 7 - free - (3.5k)
=> 34 3907029101 ada1 GPT (1.8T)
=> 34 3907029101 ada2 GPT (1.8T)
=> 34 3907029101 ada3 GPT (1.8T)
=> 34 3907029101 ada4 GPT (1.8T)
=> 34 3907029101 ada5 GPT (1.8T)
=> 63 125030337 da0 MBR (59G)
63 1930257 1 freebsd [active] (942M)
1930320 63 - free - (31k)
1930383 1930257 2 freebsd (942M)
3860640 3024 3 freebsd (1.5M)
3863664 41328 4 freebsd (20M)
3904992 121125408 - free - (57G)
=> 0 1930257 da0s1 BSD (942M)
0 16 - free - (8.0k)
16 1930241 1 !0 (942M)Code:
[root@freenas] ~# glabel status
Name Status Components
gptid/38009294-1dcb-11e4-82ae-d05099013a39 N/A ada0p2
gptid/38b76d59-1dcb-11e4-82ae-d05099013a39 N/A ada1p2
gptid/3965262b-1dcb-11e4-82ae-d05099013a39 N/A ada2p2
gptid/3a143aab-1dcb-11e4-82ae-d05099013a39 N/A ada3p2
gptid/3ac8051b-1dcb-11e4-82ae-d05099013a39 N/A ada4p2
gptid/3b79f677-1dcb-11e4-82ae-d05099013a39 N/A ada5p2
ufs/FreeNASs3 N/A da0s3
ufs/FreeNASs4 N/A da0s4
ufs/FreeNASs1a N/A da0s1a
Tried to online it:
[root@freenas] ~# zpool online Deerhaven1 /dev/gptid/38b76d59-1dcb-11e4-82ae-d05099013a39.eli warning: device '/dev/gptid/38b76d59-1dcb-11e4-82ae-d05099013a39.eli' onlined, but remains in faulted state use 'zpool replace' to replace devices that are no longer present
And the drive info:
[root@freenas] ~# smartctl -q noserial -a /dev/ada1
smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p9 amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red (AF)
Device Model: WDC WD20EFRX-68EUZN0
Firmware Version: 80.00A80
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Aug 9 21:28:09 2014 CDT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
data collection: (26460) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 267) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 175 175 021 Pre-fail Always - 4241
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 14
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 67
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 14
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 11
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 10
194 Temperature_Celsius 0x0022 111 100 000 Old_age Always - 36
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Conveyance offline Completed without error 00% 67 -
# 2 Short offline Completed without error 00% 67 -
# 3 Short offline Completed without error 00% 66 -
# 4 Extended offline Completed without error 00% 11 -
# 5 Conveyance offline Completed without error 00% 6 -
# 6 Short offline Completed without error 00% 5 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
