Cannot send snapshot
johan56
Hi!
So I'm trying to send a snapshot
I took the snapshot with zfs snapshot -r ubuntuDiskar/data/arkiv@arkiv
Then I'm trying to send it to another dataset zfs send -R ubuntuDiskar/data/arkiv@arkiv | zfs recv raiden/raiden
But I'm receiving the error according to the image
styno
Where are you trying to send to? A different machine or a different pool in the same machine?
styno
Can you provide the output of zpool status and zfs list?
johan56
[root@freenas ~]# zpool status
  pool: freenas-boot
state: ONLINE
  scan: none requested
		NAME		STATE	 READ WRITE CKSUM
		freenas-boot  ONLINE	   0	 0	 0
		  ada0p2	ONLINE	   0	 0	 0
errors: No known data errors
  pool: raiden
state: ONLINE
		raiden										  ONLINE	   0	 0	 0
		  raidz1-0									  ONLINE	   0	 0	 0
			gptid/955a93f9-2771-11e7-ac64-001cc4471eed  ONLINE	   0	 0	 0
			gptid/968855c5-2771-11e7-ac64-001cc4471eed  ONLINE	   0	 0	 0
			gptid/97bb1d33-2771-11e7-ac64-001cc4471eed  ONLINE	   0	 0	 0
			gptid/98de95a9-2771-11e7-ac64-001cc4471eed  ONLINE	   0	 0	 0
  pool: ubuntuDiskar
state: ONLINE
		ubuntuDiskar								  ONLINE	   0	 0	 0
		  gptid/a48bb10b-1ef9-11e7-aac9-001cc4471eed  ONLINE	   0	 0	 0
		  gptid/a8424745-1ef9-11e7-aac9-001cc4471eed  ONLINE	   0	 0	 0
		  gptid/ab177652-1ef9-11e7-aac9-001cc4471eed  ONLINE	   0	 0	 0
		  gptid/acac7ca1-1ef9-11e7-aac9-001cc4471eed  ONLINE	   0	 0	 0
[root@freenas ~]#
NAME																 USED  AVAIL  REFER  MOUNTPOINT
freenas-boot														 648M  27.7G	64K  none
freenas-boot/ROOT													640M  27.7G	29K  none
freenas-boot/ROOT/Initial-Install									  1K  27.7G   636M  legacy
freenas-boot/ROOT/default											640M  27.7G   637M  legacy
freenas-boot/grub												   6.34M  27.7G  6.34M  legacy
raiden															  17.5M  10.2T   128K  /mnt/raiden
raiden/.system													  16.5M  10.2T   140K  legacy
raiden/.system/configs-fe5739137b3643d3a6327c8c1d9b1a34			  128K  10.2T   128K  legacy
raiden/.system/cores												 901K  10.2T   901K  legacy
raiden/.system/rrd-fe5739137b3643d3a6327c8c1d9b1a34				 14.7M  10.2T  14.7M  legacy
raiden/.system/samba4												209K  10.2T   209K  legacy
raiden/.system/syslog-fe5739137b3643d3a6327c8c1d9b1a34			   477K  10.2T   477K  legacy
ubuntuDiskar														3.04T   484G	88K  /mnt/ubuntuDiskar
ubuntuDiskar/.system												8.77M   484G	96K  /mnt/ubuntuDiskar/.system
ubuntuDiskar/.system/configs-fe5739137b3643d3a6327c8c1d9b1a34		 88K   484G	88K  /mnt/ubuntuDiskar/.system/configs-fe5739137
ubuntuDiskar/.system/cores										   820K   484G   820K  /mnt/ubuntuDiskar/.system/cores
ubuntuDiskar/.system/rrd-fe5739137b3643d3a6327c8c1d9b1a34		   7.39M   484G  7.39M  /mnt/ubuntuDiskar/.system/rrd-fe5739137b364
3d3a6327c8c1d9b1a34
ubuntuDiskar/.system/samba4										  144K   484G   144K  /mnt/ubuntuDiskar/.system/samba4
ubuntuDiskar/.system/syslog-fe5739137b3643d3a6327c8c1d9b1a34		 268K   484G   268K  /mnt/ubuntuDiskar/.system/syslog-fe5739137b
ubuntuDiskar/data												   3.04T   484G   136K  /mnt/ubuntuDiskar/data
ubuntuDiskar/data/.system										   3.91M   484G	96K  /mnt/ubuntuDiskar/data/.system
ubuntuDiskar/data/.system/configs-adb946163d914f088dc14617dbc0bec3  1.50M   484G  1.50M  /mnt/ubuntuDiskar/data/.system/configs-adb9
ubuntuDiskar/data/.system/cores									  820K   484G   820K  /mnt/ubuntuDiskar/data/.system/cores
ubuntuDiskar/data/.system/perftest									92K   484G	92K  /mnt/ubuntuDiskar/data/.system/perftest
ubuntuDiskar/data/.system/rrd-adb946163d914f088dc14617dbc0bec3		88K   484G	88K  /mnt/ubuntuDiskar/data/.system/rrd-adb94616
ubuntuDiskar/data/.system/samba4									 376K   484G   376K  /mnt/ubuntuDiskar/data/.system/samba4
ubuntuDiskar/data/.system/syslog-adb946163d914f088dc14617dbc0bec3   1000K   484G  1000K  /mnt/ubuntuDiskar/data/.system/syslog-adb94
ubuntuDiskar/data/Time-Machine									  38.5G  11.5G  38.5G  /mnt/ubuntuDiskar/data/Time-Machine
ubuntuDiskar/data/arkiv											  241G   484G   241G  /mnt/ubuntuDiskar/data/arkiv
ubuntuDiskar/data/media											 2.76T   484G  2.76T  /mnt/ubuntuDiskar/data/media
ubuntuDiskar/data/pluginjails									   8.78G  10.0G   144K  /mnt/ubuntuDiskar/data/pluginjails
ubuntuDiskar/data/pluginjails/.warden-template-pluginjail--x64	   719M   484G   719M  /mnt/ubuntuDiskar/data/pluginjails/.warden-
ubuntuDiskar/data/pluginjails/.warden-template-pluginjail-9.2-x64	706M   484G   703M  /mnt/ubuntuDiskar/data/pluginjails/.warden-
ubuntuDiskar/data/pluginjails/.warden-template-standard-9.3-x64	 1.57G   484G  1.57G  /mnt/ubuntuDiskar/data/pluginjails/.warden-
ubuntuDiskar/data/pluginjails/calculatorn						   87.5M   484G  1.60G  /mnt/ubuntuDiskar/data/pluginjails/calculat
orn
ubuntuDiskar/data/pluginjails/couchpotato_1						  269M   484G   982M  /mnt/ubuntuDiskar/data/pluginjails/couchpot
ato_1
ubuntuDiskar/data/pluginjails/plexmediaserver_1					 3.54G   484G  4.23G  /mnt/ubuntuDiskar/data/pluginjails/plexmedi
aserver_1
ubuntuDiskar/data/pluginjails/transmission_1						1.94G   484G  2.62G  /mnt/ubuntuDiskar/data/pluginjails/transmis
sion_1
ubuntuDiskar/data/test											   216K   484G   216K  /mnt/ubuntuDiskar/data/test
ubuntuDiskar/data/transmission									   112K   484G   112K  /mnt/ubuntuDiskar/data/transmission
ubuntuDiskar/jails													88K   484G	88K  /mnt/ubuntuDiskar/jails
Hope I got everything!
Command not found? You probably have a broken install. Reinstall, possibly to new media, and upload your config.
johan56
Its a fresh installation on a new media, on a SSD.
ubuntuDiskar is an imported volume
