cuvy
- Jun 12, 2015
Hi there,
I've setup ZFS replication between my 2 FreeNAS servers.
I'm running 9.10 on both, I ran the replication fine then the automatic replication started failing. To debug it, I try to run the command manually as per the docs
I rebooted the remote server and it is still happening. It is worth mentioning the remote server has a Jail with the dataset mounted, I tried to shutdown the Jail + remove the storage mount but it didn't do anything.
I'm out of ideas right now...
[root@mother] ~# zfs send -v -I mother03/K@auto-20161216.0510-5d mother03/K@auto-20161216.0515-5d | ssh -i /data/ssh/replication SERVERADDRR zfs receive -v -s remoteM/K send from @auto-20161216.0510-5d to mother03/K@auto-20161216.0515-5d estimated size is 3.35M total estimated size is 3.35M TIME SENT SNAPSHOT receiving incremental stream of mother03/K@auto-20161216.0515-5d into remoteM/K@auto-20161216.0515-5d cannot receive incremental stream: dataset is busy warning: cannot send 'mother03/K@auto-20161216.0515-5d': signal received
