Cannot mount ZFS hard disk
vangelisb
Hello all
I have a pc with freenas installed on a flash drive and a 500gb hard disk for file storing
all of a sudden i could get into the share and freenas gave me an error.
i tried instaling the latest version, i unmounted the drive and tried to mount it again.
Any help would be apreciated as this disk contains some files that i need
and the latest backup is a week ago.
The error that i get when i am trying to automount the disk is below and and when i try to automount again the hdd disapears from the list
Request Method: POST
Request URL: http://10.0.0.240/storage/auto-import/
Software Version: FreeNAS-9.1.1-RELEASE-x86 (a752d35)
Exception Type: KeyError
Exception Value:
'volume'
Exception Location: /usr/local/www/freenasUI/../freenasUI/storage/forms.py in done, line 667
Server time: Wed, 22 Jan 2014 06:49:36 -0800
Traceback
Environment:
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
109. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_view
165. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
25. return view_func(request, *args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/views/generic/base.py" in view
68. return self.dispatch(request, *args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/formtools/wizard/views.py" in dispatch
227. response = super(WizardView, self).dispatch(request, *args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/views/generic/base.py" in dispatch
86. return handler(request, *args, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/formtools/wizard/views.py" in post
290. return self.render_done(form, **kwargs)
File "/usr/local/lib/python2.7/site-packages/django/contrib/formtools/wizard/views.py" in render_done
332. done_response = self.done(final_form_list, **kwargs)
File "/usr/local/www/freenasUI/../freenasUI/storage/forms.py" in done
667. vol = cdata['volume']
Exception Type: KeyError at /storage/auto-import/
Exception Value: 'volume'
Request information
GET
No GET data
POST
VariableValue
2-__all__ u''
2-volume_disks u'hdd500g|2273334859262152053'
__form_id u'dijit_form_Form_2'
auto_import_wizard-current_step u'2'
FILES
No FILES data
COOKIES
VariableValue
csrftoken 'SCpMsjbBE2DLF97rqIvzQAVDQPPWr0Q1'
sessionid '78ts4ukogi5n0qeqsrqovwim5gyqpei5'
fntreeSaveStateCookie 'root%2Croot%2F56%2Croot%2F56%2F63%2Croot%2F56%2F63%2F64'
META
VariableValue
wsgi.multiprocess False
HTTP_REFERER 'http://10.0.0.240/'
REDIRECT_STATUS '200'
SERVER_SOFTWARE 'nginx/1.4.1'
SCRIPT_NAME u''
HTTP_X_CSRFTOKEN 'SCpMsjbBE2DLF97rqIvzQAVDQPPWr0Q1'
REQUEST_METHOD 'POST'
PATH_INFO u'/storage/auto-import/'
HTTP_ORIGIN 'http://10.0.0.240'
SERVER_PROTOCOL 'HTTP/1.1'
QUERY_STRING ''
CONTENT_LENGTH '117'
HTTP_USER_AGENT 'Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/32.0.1700.76 Safari/537.36'
HTTP_CONNECTION 'keep-alive'
HTTP_COOKIE 'fntreeSaveStateCookie=root%2Croot%2F56%2Croot%2F56%2F63%2Croot%2F56%2F63%2F64; csrftoken=SCpMsjbBE2DLF97rqIvzQAVDQPPWr0Q1; sessionid=78ts4ukogi5n0qeqsrqovwim5gyqpei5'
SERVER_NAME 'localhost'
REMOTE_PORT '24333'
wsgi.url_scheme 'http'
SERVER_PORT '80'
SERVER_ADDR '10.0.0.240'
DOCUMENT_ROOT '/usr/local/etc/nginx/html'
HTTP_CONTENT_LENGTH '117'
HTTP_X_REQUESTED_WITH 'XMLHttpRequest'
DOCUMENT_URI '/storage/auto-import/'
wsgi.input <flup.server.fcgi_base.InputStream object at 0x2c33a1ec>
HTTP_HOST '10.0.0.240'
wsgi.multithread True
HTTP_CONTENT_TYPE 'application/x-www-form-urlencoded'
REQUEST_URI '/storage/auto-import/'
HTTP_ACCEPT '*/*'
wsgi.version (1, 0)
GATEWAY_INTERFACE 'CGI/1.1'
wsgi.run_once False
wsgi.errors <flup.server.fcgi_base.TeeOutputStream object at 0x2c5923cc>
REMOTE_ADDR '10.0.0.247'
HTTP_ACCEPT_LANGUAGE 'el,en;q=0.8,nl;q=0.6,de;q=0.4'
CSRF_COOKIE u'SCpMsjbBE2DLF97rqIvzQAVDQPPWr0Q1'
HTTP_ACCEPT_ENCODING 'gzip,deflate,sdch'
Knowltey
Looks like part of the web interface has become corrupted on your install. Try reinstalling a fresh FreeNAS image to the flash drive and see if that resolves the issue for you.
vangelisb
I forgot to mention that i have already tried reinstalling on Another drive the new version freenas and i had the same problem
Knowltey
dlavigne meant the whole output of the zpool status command in code tags to preserve formatting.
