SOLVED Cannot load plugins
operator
on my freenas 11.2 (actually version) i cannot read the plugin list for install. See code and screenshot.
Full code #1
Cmd('git') failed due to: exit code(128) cmdline: git clone -v https://github.com/freenas/iocage-ix-plugins.git /mnt/daten/iocage/.plugin_index stderr: 'Cloning into '/mnt/daten/iocage/.plugin_index'... fatal: unable to access 'https://github.com/freenas/iocage-ix-plugins.git/': Could not resolve host: github.com '
Full code #2
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 166, in call_method
    result = await self.middleware.call_method(self, message)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1093, in call_method
    return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1037, in _call
    return await self._call_worker(name, *args)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1058, in _call_worker
    return await self.run_in_proc(main_worker, name, args, job)
  File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 990, in run_in_proc
    return await async_run_in_executor(loop, executor, method, *args, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/middlewared/utils/asyncio_.py", line 41, in async_run_in_executor
    raise result
RuntimeError: Cmd('git') failed due to: exit code(128)
Samuel Tai
Check Network->Network Summary. Do you have a default gateway defined? Do you have DNS servers defined? Both are needed for the plugin lookup to work.
operator
Interesting. I imported older settings from 9.2 but there woldn't be imported completely...
Now is working. Thanks.
