MisterE2002
- Sep 5, 2015
Received a degraded pool mail. Verified using command line
Checked the logs on disk
So, it kicked ada9 with serial JEJ15JBN
My first obvious step would be to do a SMART test.
But i think the drive is *really* kicked.
Can not see the drive using " geom disk list" or "camcontrol devlist".
What are the best steps to proceed?
* reboot system?
* hope the drive is visible again
* If visible, smart check
* re-add drive or warranty replacement
or:
* shutdown system
* remove drive. Attach to Linux
* SMART test in Linux.
* Keep system off until replacement disk
pool: tank
state: DEGRADED
status: One or more devices has been removed by the administrator.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: scrub repaired 0 in 0 days 13:35:13 with 0 errors on Mon May 18 13:35:15 2020
NAME STATE READ WRITE CKSUM
tank DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/8ad6d742-735d-11e9-b886-00074305cc8f ONLINE 0 0 0
gptid/8e663a45-735d-11e9-b886-00074305cc8f ONLINE 0 0 0
gptid/91df67e8-735d-11e9-b886-00074305cc8f ONLINE 0 0 0
gptid/9600e8ca-735d-11e9-b886-00074305cc8f ONLINE 0 0 0
gptid/9983ada6-735d-11e9-b886-00074305cc8f ONLINE 0 0 0
gptid/9da62577-735d-11e9-b886-00074305cc8f ONLINE 0 0 0
gptid/a15101a1-735d-11e9-b886-00074305cc8f ONLINE 0 0 0
gptid/a4e57169-735d-11e9-b886-00074305cc8f ONLINE 0 0 0
gptid/a9221554-735d-11e9-b886-00074305cc8f ONLINE 0 0 0
11480871015459646449 REMOVED 0 0 0 was /dev/gptid/acd52da1-735d-11e9-b886-00074305cc8fChecked the logs on disk
Jun 18 05:06:46 nas2 ada9 at ahcich13 bus 0 scbus13 target 0 lun 0 Jun 18 05:06:46 nas2 ada9: <WDC WD100EFAX-68LHPN0 83.H0A83> s/n JEJ15JBN detached Jun 18 05:06:46 nas2 ZFS: vdev state changed, pool_guid=11356577163475570859 vdev_guid=11480871015459646449 Jun 18 05:06:46 nas2 ZFS: vdev is removed, pool_guid=11356577163475570859 vdev_guid=11480871015459646449 Jun 18 05:06:46 nas2 GEOM_MIRROR: Device swap0: provider ada9p1 disconnected. Jun 18 05:06:46 nas2 (ada9:ahcich13:0:0:0): Periph destroyed Jun 18 05:06:48 nas2 ZFS: vdev state changed, pool_guid=11356577163475570859 vdev_guid=11480871015459646449 Jun 18 05:06:52 nas2 GEOM_ELI: Device mirror/swap0.eli destroyed. Jun 18 05:06:53 nas2 savecore: /dev/ada8p1: Operation not permitted Jun 18 05:06:53 nas2 GEOM_MIRROR: Device swap0: provider destroyed. Jun 18 05:06:53 nas2 GEOM_MIRROR: Device swap0 destroyed. Jun 18 05:07:04 nas2 (aprobe0:ahcich13:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Jun 18 05:07:04 nas2 (aprobe0:ahcich13:0:0:0): CAM status: ATA Status Error Jun 18 05:07:04 nas2 (aprobe0:ahcich13:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 04 (ABRT ) Jun 18 05:07:04 nas2 (aprobe0:ahcich13:0:0:0): RES: 51 04 00 00 00 00 00 00 00 00 00 Jun 18 05:07:04 nas2 (aprobe0:ahcich13:0:0:0): Retrying command Jun 18 05:07:04 nas2 (aprobe0:ahcich13:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Jun 18 05:07:04 nas2 (aprobe0:ahcich13:0:0:0): CAM status: ATA Status Error Jun 18 05:07:04 nas2 (aprobe0:ahcich13:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 04 (ABRT ) Jun 18 05:07:04 nas2 (aprobe0:ahcich13:0:0:0): RES: 51 04 00 00 00 00 00 00 00 00 00 Jun 18 05:07:04 nas2 (aprobe0:ahcich13:0:0:0): Error 5, Retries exhausted
* reboot system?
or:
* shutdown system
