mhweb
 - Aug 4, 2019
I'm building my first FreeNAS server to store data and use Plex, and knowing that using RAIDZ2 can only protect you from two disk failures and it's not possible to expand the array one drive at a time, is it a solution to create multiple RAIDZ1 pools with a minimum of 3 drives and expand the storage using the vdev expand feature? If I have a storage made of multiple drive pool, if I lose one of the RAIDZ1 pools will I lose all the data on the entire server or just that one RAIDZ1 pool?
