Cam errors (ICRC ABRT ; drd serv err)
Arjan
Dear experts,
After playing around with old Freenas builds (0.5; 05; 06 ; 07) on a, now broken down server, i now started to build a new Freenas system on a cute little Dell SC1435 server.
The exact config you find in the signature.
Here is this problem i am encountering:
The machine gives permanent CAM-errors on the ada0-drive, but stays up-and-running.
This ada0 is a sata converter for a 4GB Sandisk CF-card, and is connected to the regular sata-port on the motherboard.
This flashcard is used to boot the freenas build from.
Can anyone please help me, with explaining the errorcodes, i receive ?
Thanks,
Arjan
The machine gives the following errors:
(ada0:ata2:0:0:0:0) Write_dma acb: ca 00 88 00 3b 40 00 00 00 0040 00
(ada0:ata2:0:0:0:0) CAM STATUS: ATA STATUS ERROR
(ada0:ata2:0:0:0:0) ATA STATUS: 51 (DRDY SERV ERR), ERROR: 84 (ICRC ABRT)
(ada0:ata2:0:0:0:0) RES 51 84 c8 00 3b 00 00 00 00 00 00
(ada0:ata2:0:0:0:0) RETRYING COMMAND
camcontrol gives:
[root@trifonius] /sbin# camcontrol identify ada0
pass0: <SanDisk SDCFH-004G HDX 5.09> CFA-4 SATA 1.x device
pass0: 150.000MB/s transfers (SATA 1.x, UDMA4, PIO 512bytes)
protocol ATA/ATAPI-4 SATA 1.x
device model SanDisk SDCFH-004G
firmware revision HDX 5.09
serial number BPZ032410182601
cylinders 7773
heads 16
sectors/track 63
sector size logical 512, physical 512, offset 0
CFA supported
LBA supported 7835184 sectors
LBA48 supported 7835184 sectors
PIO supported PIO4 w/o IORDY
DMA supported WDMA2 UDMA4
Feature Support Enabled Value Vendor
read ahead no no
write cache yes yes
flush cache yes no
overlap no
Tagged Command Queuing (TCQ) no no
Native Command Queuing (NCQ) no
SMART no no
microcode download no no
security no no
power management no no
advanced power management yes no 0/0x00
automatic acoustic management no no
media status notification no no
power-up in Standby no no
write-read-verify no no
unload no no
free-fall no no
Data Set Management (DSM/TRIM) no
Host Protected Area (HPA) no
[root@trifonius] /sbin# smartctl -a /dev/ada0
smartctl 6.1 2013-03-16 r3800 [FreeBSD 9.1-STABLE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model: SanDisk SDCFH-004G
Serial Number: BPZ032410182601
Firmware Version: HDX 5.09
User Capacity: 4,011,614,208 bytes [4.01 GB]
Sector Size: 512 bytes logical/physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ATA/ATAPI-4 (minor revision not indicated)
Local Time is: Sun Jan 5 13:33:23 2014 CET
SMART support is: Unavailable - device lacks SMART capability.
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
Your flash media is taking too long to be accessed and its causing those errors. While that error can be safely ignored, the problem is that the media is so slow it could cause data loss later. That's obviously bad and needs to be corrected.
Not sure which Sandisk Ultra you have, but the issue could also be with your CF to SATA converter not being a good quality or is going bad. Do note that the throughput of your CF card may not be the problem, but the latency between reads and writes may be the problem. Normally, I'd think that any Sandisk Ultra CF card would be acceptable for this use, so I'd eyeball the CF to SATA converter first.
Arjan
Thanks Cyberjock,
I hoped for a fix in some of the settings, but your answer is loud 'n clear, and i'll go after the cf-card to sata converter and/or the card itself. (Sandisk 4g with 30 Mb/s.)
Fact is, that the converter is some cheap Chinese card, and that the CF-card (now i'm thinking of it) is several years old.
Think i'll switch to a usb-stick to boot from, and see what is happening then.
Regards,
Arjan
Arjan
And in the end, swapping the sata-cable did the trick........;)
Interesting! I didn't even think of that to be honest.
Good try!
