cacert.org as certificate authority
go4freenas
hello
i new to freenas. til now i have used debian apache2 mysql php5 systems.
as CA i use cacert.org. in debian i could install the cacert root certificate on the commandline.
how do i install the cacert root certificate in the freenas 9.3 webgui.
kind regards
Why do you want to install the root CA certificate onto your FreeNAS server? What do you hope to accomplish thereby? You can probably do it under System -> CAs -> Import CA, but it's unlikely that it will benefit you at all.
go4freenas
you are right. i forgot not the server needs the cacert root certificates the clients need them.
kind regards.
