cabling issue
Nerdlinger
FreeNAS-9.10.2
48GB registered ECC RAM
Motherboard: supermicro X8DTU-F
2x 8 TB WD Red running in zfs mirror
IBM ServeRAID M1015 in IT mode
SuperMicro SuperServer 6026T-URF
I was mucking about in my server case, rerouting some cables. When I was done, I booted. unfortunately, one of my two drives wasn't plugged in. So yup, it comes up and tells me about the bad drive. I shut everything down, made sure the drive was plugged in (D'oh), and it booted fine, and I see no MORE errors.
It never resilvered or anything like that. I think it is highly unlikely that anything even got out of sync (possibly a date/time in a log file or something like that).
I issued a zfs clear, and everything appears happy.
So what is the correct behavior the next time it happens? run a scrub? zfs clear? or ????
m0nkey_
All disks are now available so this is no longer an issue. You can run a scrub manually to make sure you've not caused any issues, but the chances of that are slim.
rs225
If you check zpool status, it should indicate that it repaired or resilvered a very small amount of data. It is automatic, and takes only as long as the amount of changed data. For more severe incidents, it may start a metadata scan to look for changes. If it doesn't show the repaired message, possibly some other command already ran that replaced that message.
