bydirectional sync with rsync
ShadowSkippie
Morning
I've been struggling to get this right
How can i use rsync to perform a by-direction synchronization between 2 servers
Joshua Parker Ruehlig
Morning
rsync really isn't designed to do this. btsync works, there's also csync (the backend owncloud uses).
i guess it could be possible though, just only update if changes are newer on the other side. you'd need to setup a job in both directions
achianese
Assuming you want updates to either side to be propagated, this is what Unison is designed for. Very easy to install by copying the BSD binaries to a bin folder in your pool. Search the forums for the method.
