Crotalus
- May 5, 2015
Hi there,
I recently retired after working in the IT environment for more than 30 years. The company decided that I could be replaced by someone from India. I wrote my first program, assembler for an IBM 370. Also used PL/I and COBOL for years. Had some contact with HP-UNIX as a developer using C with some system administration.
I have had a FreeBSD sever currently running Version 9.3-RELEASE in my basement for several years. It is based on an old ABIT motherboard that has 8 GB memory with an AMD Athlon socket 939 single core processor running at 2.2 Gz. I have MySQL, SAMBA, Tomcat, and HTTP installed and used. The only problems have been with hardware. Things like hard drives buying the farm. The thing is fast for old hardware.
I put together a FreeNAS box as follows;
Motherboard ---> ASRock E3C226D2I
Processor -------> Intel Core i3-4370 LGA
CPU Cooler -----> Noctua NH-U12S
Memory ---------> Crucial EEC 16GB (8 x 2)
Flash Drive -----> PNY 16GB
Hard Drives ----> HGST HUS724020ALE640 (4 2TB HHD for a total of 8TB)
PSU -------------> Silencer MX III Semi-modular 500 Watt
Case -------------> Fractal Design Node 304
The wire management in the case was a nightmare, but it is a great little case. I have the unit in my basement and I placed a thermometer over the fan in the back and the highest temperature has been 74F. I have no idea what the CPU temperature is.
Install went well until I tried to set up the shares. Since is SAMBA is installed I thought I could use SWAT. Wrong! I could change /etc/inetd.conf and /etc/rc.conf but there are no SWAT modules in FreeNAS. I also thought I could do it the easy way by editing the config file but decided not to do so. FreeNAS may be based on FreeBSD but there are changes. I got the shares to work using the GUI interface.
I have one other problem with a runaway log file that I need to fix. I may have to post the problem another area as I have yet to figure it out.
Enough babbling!
Keith
Enough babbling!
Keith
