pr1malr8ge
- Dec 10, 2017
Let me first set up some info to help understand what I am trying to do.
I have a working FreeNAS system that I hobbled together few years ago. It has 5 1tb drives that are 75% full.
In my decision to upgrade I decided it would be wiser to build a new machine. I purchased a used sm826 with an x9dri-lnf4 with a lsi9201-8i [don't quote me on that] and 9 used HGST 7400k Ultrastar 3tb drives, I plan on using 6 drives to start in raidz2.
I went through and have burned in the new system. [2 of the drives are going to be RMAd for being bad] I'm currently planning on running 6 of those 3tb drives raidz2.
So as it stands the new system is up with its own basic config and set IP but not a clone of the current working machine. I have the 6 drives in and created my pool. I named that pool the same as the pool on the working machine. I set up replication on the working machine to replicate to the new machine. How ever I got this error message "Jan. 31, 2018, 8:45 p.m. - Replication dataset1 -> 192.168.254.201:dataset1 failed: Please move system dataset of remote side to another pool" So I tested if I created a sub data set if that would work and it did.
The issue is it's not a true clone.
Here is what the pool looks like on the working machine
This is what the replicated set on the new machine looks like, keep in mine the transfer isn't done so a few things are not present yet..
Please help me.. I do not want to physically have to move the drives out of the old machine into the new machine. Blowing the new machines pool away and starting over is ok. I'm not exactly in a rush.
I want to note, that I just need right now to clone the old machines zfs to the new. once that happens I will shut down the old machine and upload its config to the new machine and it should then be as if the old machine just rebooted.
