Joakim Ollila
- Jun 6, 2015
I am building my first freenas server. But I have a problem what rackmount chassi should I buy? and from where? I am in europe and it's really hard to find supermicro chassi or good chassi that take more than 16 drives for a cheap price. Only ones I find is around 1000 dollars. I am thinking about supermicro x9srk-7f motherboard. This as my cpu E5-1620v2 then some compatible ecc ram memory 32gb..
Then hopefully has the chassi a power supply.. Then I like to have a possibility to add up to 24 drives. So i probably need some sata card or what do you suggest?
Should I buy a ssd for plex jails and metadata? Or just buy a ssd to be my l2arc?
I am going to use plex to about 10 users internally or externally.
Then I was going to use it for surveillance cameras but freenas dosen't support any surveillance camera software? So i was thinking about maybe buying a nvr for surveillance and then use some of the disk from the freenas server to storage for the cameras.
Or do you have any other logical solutions?
Thanks
Thanks
