Hello!
Version:
TrueNAS-12.0-U3.1
I noticed that in Active Directory Settings there is some checkbox like "Verbose Logging", but i can't see it in LDAP settings... maybe this is that error?
Grettings!
Version:
TrueNAS-12.0-U3.1
root@truenas[/var/log]# tail -n 50 middlewared.log [2021/05/18 17:02:36] (DEBUG) freenasOS.Configuration.CheckFreeSpace():77 - CheckFreeSpace(path=/tmp/tmpym1osl7d, pool=None, required=185) [2021/05/18 17:02:36] (DEBUG) freenasOS.Configuration.TryGetNetworkFile():745 - TryGetNetworkFile(['https://update.ixsystems.com/TrueNAS/Validators/ValidateUpdate-mg3ef525.txt', 'https://update-master.ixsystems.com/TrueNAS/Validators/ValidateUpdate-mg3ef525.txt']): Read 185 bytes total [2021/05/18 17:02:52] (DEBUG) LDAPService._open():249 - SASL EXTERNAL bind failed. Traceback (most recent call last): File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/ldap.py", line 244, in _open if self.ldap['verbose_logging']: KeyError: 'verbose_logging' [2021/05/18 17:02:52] (ERROR) middlewared.job.run():379 - Job <bound method LDAPService.do_ldap_query of <middlewared.plugins.ldap.LDAPService object at 0x81c433220>> failed Traceback (most recent call last): File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 367, in run await self.future File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 405, in __run_body rv = await self.middleware.run_in_thread(self.method, *([self] + args)) File "/usr/local/lib/python3.8/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/ldap.py", line 778, in do_ldap_query ret = LDAP.validate_credentials() File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/ldap.py", line 137, in validate_credentials ret = self._open() File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/ldap.py", line 277, in _open self._convert_exception(saved_simple_error) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/ldap.py", line 161, in _convert_exception raise CallError(str(ex)) middlewared.service_exception.CallError: [EFAULT] 'verbose_logging' [2021/05/18 17:02:54] (DEBUG) LDAPService._open():249 - SASL EXTERNAL bind failed. Traceback (most recent call last): File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/ldap.py", line 244, in _open if self.ldap['verbose_logging']: KeyError: 'verbose_logging' [2021/05/18 17:02:54] (ERROR) middlewared.job.run():379 - Job <bound method LDAPService.do_ldap_query of <middlewared.plugins.ldap.LDAPService object at 0x81c433220>> failed Traceback (most recent call last): File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 367, in run await self.future File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 405, in __run_body rv = await self.middleware.run_in_thread(self.method, *([self] + args)) File "/usr/local/lib/python3.8/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/ldap.py", line 778, in do_ldap_query ret = LDAP.validate_credentials() File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/ldap.py", line 137, in validate_credentials ret = self._open() File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/ldap.py", line 277, in _open self._convert_exception(saved_simple_error) File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/ldap.py", line 161, in _convert_exception raise CallError(str(ex)) middlewared.service_exception.CallError: [EFAULT] 'verbose_logging'
Grettings!
