BTSync: .SyncArchive does not store deleted files on FreeNAS
Clouseau
System:
FreeNAS-9.2.1.6-RELEASE-x64
Btsync 1.3.106 btsync-1.3.106-amd64
I noticed that deleted files are not Archived as it should. By default you should have 30 days arvhive but when files are deleted using CIFS shares which are synced between two FreeNAS servers with BTSync you can't find any archieved files. If you sync files with FreeNAS and Windows PC you can find archieved files only in Windows side in hidden folder .SyncArchive.
SyncArchive working:
Windows: YES
FreeNAS: NO
Store deleted files in SyncArchive is checed also in web GUI!
Can anyone confirm this? Feature or bug?
Clouseau
Anyone?
I have settings in each synced folder: Store deleted files in SyncArchive, but you cant see any stored deleted files in SyncArchive - WHY?
Also the default value to store the files is: Trash Time to live (days):30
This forum isn't for BTSync. That's probably why you aren't getting responses. ;)
Clouseau
This part of the forum is for Plugins and BTSync is one of the FreeNAS plugins!
