Not sure if anyone is having the same issue but have ran across this many many times across many installs. The problem i keep running into is any time i create a VM everything deploys fine for the first VM. If i ever remove a VM i keep getting the following
I've tried sifting through the code and it seems like the issue is related to
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 137, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1215, in _call
File "/usr/lib/python3/dist-packages/middlewared/service.py", line 469, in create
rv = await self.middleware._call(
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1021, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vms.py", line 105, in do_create
await self.middleware.run_in_thread(self._check_setup_connection)
File "/usr/lib/python3/dist-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/lib/python3/dist-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 41, in _check_setup_connection
if not self._is_connection_alive():
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/connection.py", line 34, in _is_connection_alive
def _is_connection_alive(self):
File "/usr/lib/python3/dist-packages/libvirt.py", line 4370, in isAlive
if ret == -1: raise libvirtError ('virConnectIsAlive() failed', conn=self)
libvirt.libvirtError: invalid connection pointer in virConnectIsAliveI've tried sifting through the code and it seems like the issue is related to
ret = libvirtmod.virConnectIsAlive(self._o)Code:but haven't confirmed that yet. So far the only fix is reboot the entire system unless there is some services that can be restarted i am unaware of. I'm curious to other peoples milage here, because as stated before i have installed several SCALE version many times over the last few months and this problem has always persisted. This all but makes the VM implementation unusable and can't see how others aren't having the same given how long the problem has been around. Given how much KVM & VMs are being toted in SCALE seems like not much effort has been put into actually getting it working when compared to the bhyve in Core.
