Bridge0 disapear after reboot
P4#0383
First time in this forums as well as using FreeNAS.
FreeNAS ver. 11.22-U7
nextcloud 11.2-RELEASE-p15
I am running into some issues with losing bridge0 which causes lost connection between the storage and the nextcloud jail pluging.
I have been looking for answers on this issue and my research had drove me to a very short road, very much to "we can reproduce the issue" and the bug reports get shutdown. I was to find information on creating the bridge0 but, it does not connect to the jail running nextcloud.
The scenario is very simple, I installed FreeNAS, then install the Plugin for nextcloud. Configured the nextcloud networking usually with a static IP address before the jail is crated. Once the jail is running, all work find, I can reach the storage and upload my content. However, one the system reboots, the bridge is missing from Network -> Network Summary. Please see attachments.
When I look at the interfaces I can see the bridge0
From within FreeNAS CLI:
bridge0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether 02:80:b1:c4:1f:00
nd6 options=1<PERFORMNUD>
groups: bridge
root id 00:00:00:00:00:00 priority 0 ifcost 0 port 0
The memeber are missing from the bridge in FreeNAS.
And there is not bridge in the jail:
From within nextcloud jail:=
ifconfig: interface bridge0 does not exist
Any advice on how to fix this issue will be greatly appreciated.
Chris Moore
did you create the bridge from the CLI?
P4#0383
Hi Chirs,
I am unsure why this is relevant but, I will satisfied your question.
The bridge was created when nexcloud plugin was installed.
I am concern that everytime the systems is rebooted for X or Y reason, the bridge is lost.
I still wondering why when I reboot the system the bridge is lost, I think I am going on my fifth time I have to backup all my data, remove and reinstall nextcloud plugin. This looks more and more like a bug in the code.
How can this be fixed without removing and reinstalling nextcloud plugin?
Thank you in advance.
P4#0383
Hello to all,
Does anyone here has a possible solution to my question?
Anyone?
Thank you in advance for all your assistance.
