GrumpyBear
- Jan 28, 2015
Well it's been almost a year with my FreeNAS and I'm still loving it.
A funny thing has happened though. My workstation with its lowley i3-2100 in a X9SCL was getting increasingly envious of the e3-1231v3 in the X10SL7-F. As outlined in my original build thread I had originally contemplated using the X9SCL for the NAS but had decided against it.
A year later I decided that the NAS was just not an efficient use of the processor (which sits mostly idle or below 2 threads) so I swapped the motherboards and CPUs. The bulk of the work was going from a 8x3TB ZFS3 to a six disk ZFS2 as the X9 has only 6 SATA2 ports. So I added 2 more of the Western Digital Reds as they appear to be more consistent and added moved the 4 Seagate disks from my original build to my workstation and reflashed the LSI2308 back to IR mode and created a 5.4TB RAID10 for local data.
I use the workstation mostly for Lightroom and PhotoShop and it is definetly more peppy both building previews and loading 100% views in Develop mode. Though disk access was not a bottleneck in either App I had to do a rather ugly hack to make Lightroom use a network drive and I do some video editing and transcoding that having the fast local storage will help with. I will be setting up a sync job to mirror the data over to the NAS.
I was able to use my mirrored USB sticks to get FreeNAS back up and running in under an hour including rebuilding the LAG and the new Pool. Rather embarrassing considering the 8 hours to get Windows 7 functional. I am sorely missing the IPMI though.
Moving the Data back from the Synology NAS I use for the on-site backup took under a day.
I'm waiting for the new socket 1151 boards from SuperMicro to become available and stable so sometime next year I may reverse the process again. Then the X9SCL will likely be repurposed to replace my LAMP server which is currently running 4 Servers on a dual core atom with 2GB RAM!
