Hello.
The scrub on the USB boot stick results in errors:
# zpool status -v freenas-boot
pool: freenas-boot
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub in progress since Mon Oct 5 05:53:43 2020
1.84G scanned at 376M/s, 0 issued at 0/s, 14.4G total
0 repaired, 0.00% done, no estimated completion time
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 2
gptid/43848064-e490-11e5-a609-b05ada8776b4 ONLINE 0 0 4
freenas-boot/ROOT/11.3-U5@2020-04-16-05:12:13:/usr/local/lib/libpkg.so.4
freenas-boot/ROOT/11.3-U5@2020-04-16-05:12:13:/usr/local/x86_64-portbld-freebsd11.0/bin/ar
Questions:
pool: freenas-boot
state: ONLINE
Questions:
- What is the best option here?
- It is possible to just restore the corrupt files? What is the best option here?
- It is possible to 'just' start the installation integrity verification against the online repository and repair the installation?
- It is better to replace the USB stick and have a new installation + restore the settings?
- It is possible to have two USB stick in parallel as the boot pool? I.e. if one of them become damages, just replace it and resilver the boot pool...
