Hallo Forum,
beim NAS eines Freundes ist wahrscheinlich die Boot-SSD defekt (oder zumindest der darauf befindliche Pool):
Die Partition ist noch da:
Allerdings ist kein Pool mehr da:
Lässt sich hier noch etwas machen, oder ist die Installation einfach hinüber?
root@nas[~]# zpool status -v pool: boot-pool state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A scan: scrub repaired 0B in 00:00:32 with 4 errors on Thu Nov 11 03:45:32 2021 config: NAME STATE READ WRITE CKSUM boot-pool ONLINE 0 0 0 ada1p2 ONLINE 0 0 4 errors: Permanent errors have been detected in the following files: boot-pool/ROOT/12.0-U6@2021-01-07-10:46:50:/root/caddy/freenas-iocage-caddy/includes/caddy boot-pool/ROOT/12.0-U6@2021-01-07-10:46:50:/root/caddy/freenas-iocage-caddy/.git/hooks/commit-msg.sample boot-pool/ROOT/12.0-U6@2021-01-07-10:46:50:/root/caddy/freenas-iocage-caddy/.git/hooks/update.sample boot-pool/ROOT/12.0-U6@2021-01-07-10:46:50:/root/caddy/freenas-iocage-caddy/includes/Caddyfile.example pool: tb2 state: ONLINE scan: scrub repaired 0B in 05:07:55 with 0 errors on Mon Nov 1 05:07:56 2021 config: NAME STATE READ WRITE CKSUM tb2 ONLINE 0 0 0 gptid/c9bddd4d-25ec-11eb-b148-a8a15942dbb6 ONLINE 0 0 0 errors: No known data errors pool: tb3 state: ONLINE scan: scrub repaired 0B in 00:06:31 with 0 errors on Thu Nov 4 00:06:32 2021 config: NAME STATE READ WRITE CKSUM tb3 ONLINE 0 0 0 gptid/e37c7475-26aa-11eb-a4b3-a8a15942dbb6 ONLINE 0 0 0 errors: No known data errors
root@nas[~]# gpart show /dev/ada1 => 40 234441568 ada1 GPT (112G) 40 532480 1 efi (260M) 532520 33554432 3 freebsd-swap (16G) 34086952 200343552 2 freebsd-zfs (96G) 234430504 11104 - free - (5.4M)
root@nas[~]# zpool import no pools available to import
